engine mods
Old Feb 21, 2010 | 06:46 PM
  #21
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
I have read that with TFS heads and different cams you would be making 350rwhp at ~7000rpm and with a TFS H/C/I combo you could be anywhere from 375-400rwhp BUT your shift points would be 7000+rpm. And with the stockblock still in there I don't think his engine or tranny will like seeing those high rpms.
With the OP's $5000 budget he won't be able to get the full potential out of the TF heads.
Old Feb 21, 2010 | 07:23 PM
  #22
Dteal23's Avatar
Dteal23
if you are going to do a blower, build you bottom end. if you go the heads and cam route you're still going to be limited power wise because of your internals... not spending another dime on my car untill I forge mine
Old Feb 21, 2010 | 07:32 PM
  #23
98redstang's Avatar
98redstang
Originally Posted by H0SS302
Im becoming more and more anti bolt on every day. The only bolt ons that are worth their coin are LT headers. TB/plenum is a waste of money as far as i am concerned.
If your gonna spend money on n/a, go for the heavy hitter stuff= cams, heads, headers. when it comes down to it, for bolt on cars whoever has the lower gear is gonna win 9/10x with drivers who no what the heck they are doing.
+1 op dont waste your time with a tb/pl. Its really not worth it. go with heads/cams and gears if your going n/a. Maybe even consider getting the block bored out.
Old Feb 21, 2010 | 08:33 PM
  #24
Mustang_NTriangle's Avatar
Mustang_NTriangle
Originally Posted by teej281
If you do heads/cams/intake along with a blower...youre asking for trouble. You'll be making way to much power for the stock internals to handle. So either forego the h/c/i combo and put that money towards internals, or skip the blower for now and do the h/c/i combo with new internals and then save for the blower. I'd do the later of the two, but thats just me liking to prepare for the power before i actually make it. I mean a centri blower at 8-10lbs of boost is safe on the stock block, but not with heads/cams/intake. People on here are pushing it with blower cams and a supercharger, let alone heads and an aftermarket intake manifold. I think you should think about what you wanna do first and go from there. I'd do the rotating assembly and h/c/i combo first that way you just save for supporting mods and then decide on what blower or turbo you want to buy. Just make sure youre compression is about 9.2:1 for centri blowers or turbos(turbos you might wanna be a little lower) and somewhere in the 8.5:1 compression ratio for a twin screw like a kenne bell, or somewhere in the 8's for compression.
Well if OP opts for blower cams and heads we could run big pulley to keep boost level low i.e. 6 psi he would be at limits of stock block. Blower cams actually reduce psi level which is a good thing for stock internals. I would opt to go with blower cams and keep stock heads just port them and upgrade springs and retainers and you will be good to go.
Old Feb 21, 2010 | 11:56 PM
  #25
teej281's Avatar
teej281
4.6L Section Moderator
OP, check out Modular Mustang Racing(MMR). They have rotating assemblies for sale and you can get the TFS heads straight from them and they can also port them. They stated in an email once that their ported trickflow heads went up like 10-15cfm per stage from fast-as-cast and they start out at like 243cfm. They claim a gain of 45-50hp increase over the fast-as-cast units. So youre looking at anywhere from 270-280cfm on the intake side. So you could buy all your parts from one place. I think they have the trickflow intake manifold too.
Old Feb 22, 2010 | 12:15 AM
  #26
5pointslow91's Avatar
5pointslow91
hoss love ur sig, my friend showed me that youtube vid afew days ago, is it new?
Old Feb 22, 2010 | 04:03 AM
  #27
billyTHEkid1086's Avatar
billyTHEkid1086
After countless hours of reading articles after articles and discussions on this site, I think I'll end up going with a KB twin screw set up. I'll call it safe and upgrade the internals to forged components, as well as TF heads and blower cams. I think it will really hold its own at the track and while driving to work with just those upgrades. Thanks everyone.
Old Feb 22, 2010 | 06:43 AM
  #28
teej281's Avatar
teej281
So youre doing it all at once??? Make sure you dont cop out for the 2.1 because you will find out quick that your blower will be your limiting factor for power. Go with either the 2.6L kit or try to find out if modular powerhouse still makes their 2.8L kit for the 2v and go from there. Which one are you going to do first???
Old Feb 22, 2010 | 08:33 AM
  #29
texas_stang02's Avatar
texas_stang02
good choice with the KB. i love my vortech, but if i could do it all over again i'd go with a KB (or other roots or tvs type blower). the centrifugal is great in the upper rpms, but i do most of my driving below 4000 rpm and the boost doesn't really kick in big time until i get above 4k.
Old Feb 22, 2010 | 08:52 AM
  #30
billyTHEkid1086
Well I'm going to upgrade the internals, cams, headers, and a hood (for clearance) and then slap on the KB with the intake system they have for it. I was planning on the 2.1, I like the amount of power it will give me. I'm not looking to have a 700hp monster at the moment. It still is somewhat a daily driver. I have an suv I drive more. After my next deployment though, I'm looking into an 03/04 Cobra. Thats the one I would spend the real money on. I'm just looking for a fix for for the next few years. On the KB website they keep saying use their chip and set up, would it really be too much trouble to go with another tuner?
drfister
May 3, 2018 10:38 PM
MusicCity615
Sep 27, 2015 12:53 AM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
Calizic
Aug 28, 2015 01:46 PM
inyadreems
Aug 21, 2015 09:10 AM
