Catback or CAI next month?
#21
The sound will be so terribly puny with cats, don't really sound badazz until the cats go bye-bye.
#22
I agree, if sound is of more importance than performance then definitely go with the H-pipe...
#23
#24
The best description I've ever seen is:
H-pipe = Musclecar
X-pipe = NASCAR
As I said, it all depends on whether sound or performance is you primary goal. X-pipes outperform H-pipes at the higher revs the OHC engines can reach.
Up to 5200 rpm or so they run neck-and-neck, after that the X-pipe will provide significantly more torque right up to the rev-limiter--it may not sound as good, but it does provide another 700+ RPM of usable powerband.
#25
H-pipe = Musclecar
X-pipe = NASCAR
H-pipe = Musclecar
X-pipe = NASCAR
#28
http://www.americanmuscle.com/slp-ce...converter.html
You can get cats that don't have to be welded in.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
