Need a Custom Supercharger Setup...
Old Jun 25, 2010 | 12:37 PM
  #21
knightrider09's Avatar
knightrider09
I am going to buy the SCT Xcal3 SF instead of buying it from the tuner so i can tune the car for new fuel injectors. I have also figured out the solution hopefully to my inter-cooling problem:
http://www.superchargersonline.com/p...mber=SNW-20010
Im thinking about getting this one and install it with the supercharger. all the mods i mentioned on my car have already been installed minus the supercharger and accessories. Ill fix the issue with the Shaker hood system later. but for now i will use the cooling system in the link above and go from there. this way i can get more hp out of this supercharger at higher psi's but i also need to upgrade the internals as well for added power in the long run. This will be a project indeed but it will be worth the money in the future. I will post pics up as well as dyno results. I kept the stock pulleys when i swapped them with the BBK's.
Old Jun 25, 2010 | 05:45 PM
  #22
0949er's Avatar
0949er
im confused is this posted twice? or are these 2 different questions?? or am I tripping?
Old Jun 25, 2010 | 06:43 PM
  #23
knightrider09
i think you are right LOL, i didnt even realize it.
Old Jun 25, 2010 | 09:22 PM
  #24
Rockwell28's Avatar
Rockwell28
its posted twice 0949ER
Old Jun 25, 2010 | 09:27 PM
  #25
Rockwell28's Avatar
Rockwell28
be careful with th meth injection ya car has to be tuned for it and if you dont keep an eye on th tank fluid level bc if it goes on empty for ya then you will have serious issues. they Can be cheaper than intercoolers but an intercooler will always be there no fluid to refill or anything of tha sort. should be fine just keep an eye on th fluid level
Old Jun 26, 2010 | 01:05 AM
  #26
2000AZ5.0GT's Avatar
2000AZ5.0GT
Originally Posted by 98redstang
to add to everyone elses points you need to get stock pulleys as well. UD pulleys and s/c's dont mix.
that's actually not true. People don't run them with a supercharger because it slows blower RPM relative to engine RPM, which reduces power, in a matter of speaking.
in my application, to make the power curve more similar to that of a NA car, for traction issues, I run an underdriven crank pulley, which reduces low end torque slightly (not by much), but increases the range at which I can run the blower.
If I werent, I'd either max out at a 3.6" blower pulley due to engine RPM, or limit my RPM to around 6200. Neither of which do I want to do.
Now granted, since I'm either trying to sell it, or limit the power due to the POS automatic transmission, I might actually consider going back to a bigger crank pulley, to increase low end torque, and limit my RPMs.
Anyway, sorry to thread jack, just wanted to say you're wrong, you can run underdrive pulleys with a blower, it just depends on what kind of powerband you want.
If you want more topend, run underdrives, if you want the opposite, run a stock or larger than stock crank pulley.
so, enough of the
Old Jun 26, 2010 | 05:18 AM
  #27
knightrider09
its an methanol/water injection system (chemically cooling your engine)( and increases hp)
I took a look at the install of the TTrim as well, looked like a lot of work!! hope it all worked out for you. now im trying to decide on what tires to get for sticky traction and one thats good in wet weather....
Old Jun 26, 2010 | 05:19 AM
  #28
knightrider09
should be a fairly nice setup once its all done.
Old Jun 27, 2010 | 03:46 PM
  #29
knightrider09
does anyone have this water/methanol injection setup? how is it?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mdg
Oct 1, 2015 07:04 AM
