MAF meter help
Old Aug 19, 2010 | 06:29 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
No problem...
I really don't want to sound like a broken record here, however you really should consider using the stock MAF for your car. There is no performance benefit at all to be had from the 90mm unit, and in fact with a mail-order tune there may be a downside beyond dialing in low load/rpm drive-ability.
Old Aug 19, 2010 | 06:52 PM
Bough1221's Avatar
Bough1221
really? why would the use of a 90mm be then? only if u have forced induction?
Old Aug 19, 2010 | 07:25 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Only if your engine consumes so much air that the stock 80mm MAF cannot properly meter it--as I said above the stock '02 MAF is good to over 400fwHP.
Using a bigger MAF than needed means that the entire operating range of the engine will be using only a fraction of the MAF'e metering range--this means that the MAFs ability to precisely report airflow will be lessened. Precision is important as you might expect.
In the chart shown below the maroon line represents the transfer function of the 90mm Lightning MAF, the pink line the transfer function of your stock MAF. The dashed horizontal shows the maximum amount of air your n/a engine could possibly consume.
You can see that by using the 90mm MAF the usable voltage range is 0.0 to 3.7V or so, and that in the last of the range the slope becomes quite steep.
In contrast, the stock MAF usable range is 0.0 to 4.4V, and much less steep (meaning each voltage "step" is a more precise measure of air flow).
Also of note is that there is no way an n/a 2V is going to "peg" the stock MAF, and that is the only reason for upgrading--bigger is not always better...
Old Aug 19, 2010 | 07:36 PM
Bough1221's Avatar
Bough1221
thanks alot. ill hafta get ahold of the tuning company and make some changes to my tune.
jwog666
Dec 27, 2021 08:09 PM
2007CalSpec
Dec 13, 2020 11:42 AM
piotrek53
Oct 13, 2015 06:54 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
Sep 10, 2015 01:37 PM
