PCV delete
Old Jan 6, 2011 | 05:27 AM
uberstang1's Avatar
uberstang1
Chupacabra
You can put any breather you want on the valve cover as long as its a goodfit and noil oil leakage.
Old Jan 6, 2011 | 06:57 AM
01MGGT's Avatar
01MGGT
How would you put one inplace of the pcv valve since it's just a hole in the valve cover
Old Jan 6, 2011 | 08:31 AM
uberstang1's Avatar
uberstang1
Chupacabra
Fabricate one with a tube the same diameter of the pcv valve and just stick it in I would imagine.
Old Jan 7, 2011 | 05:25 AM
StriderTacticaL's Avatar
StriderTacticaL
I heard it was a bad idea to use PCV breather caps unless you are FI?
And speaking of PCV valves, where the heck can I get a replacement? I think my drivers-side one is clogged and leaking. I've checked 2 different dealerships and none of the knew what they were talking about...finally one quoted me like $55 for the right valve. Supposedly we are supposed to ask for the "heated" ones...
Old Jan 7, 2011 | 05:35 AM
uberstang1's Avatar
uberstang1
Chupacabra
Just walk in autozone there on the shelf, like 3 bucks, if the ford dealer doesn't know what a pcv valve is they are some serious retards working there.
Old Jan 7, 2011 | 06:05 AM
StriderTacticaL
So I read before and again just now that appearently the thing on the drivers side valve-cover with a long plastic tube going to the intake tube isn't a PCV valve...so does anyone know what it is? Cause mine is covered in oil and looks clogged up
Old Jan 7, 2011 | 04:45 PM
Kerns's Avatar
Kerns
Its a PCV valve. Although, I believe the drivers side one is built into the valve cover.
Old Jan 7, 2011 | 05:34 PM
rman101's Avatar
rman101
looked at mine today and it appears i have a little bit of oil around the edges of it maybe due to the boost draw? idk i have been getting into boost a bit more than usual. Time to do something about it!
Old Jan 7, 2011 | 05:38 PM
lizzyfan's Avatar
lizzyfan
Underboss
I'd leave it alone
PCV setup is your friend! Excessive blow thru is telling you something is wrong but a little is fine. Just run a catch can
Old Jun 12, 2011 | 07:12 PM
sinister99GT's Avatar
sinister99GT
i know this is a older thread, but the drivers side valve cover has a hose that goes to the air intake , that hose takes in fresh air to circulate through the crank case. pcv is on the pass side only.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
lmurf60
Sep 24, 2015 10:07 PM
