Starting The Auto Swap!!!
I finally decided 100% to do the auto swap on my 02 turbo GT. Here is the parts list i picked up:
-built th-400 w/Griner Billet reverse manual valve body w/transbrake
-JW Ultra bell
-JW "the wheel"
-mach 1 auto brake pedal
-B&M pro ratchet shifter
-B&M hi-tek tranny cooler
-energy suspension th-400 tranny mount
-RCR flex dipstick
-CSR tranny overflow can
-Ultimate convertor
-Autometer phantom tranny guage
-other misc. stuff
-chromoly driveshaft
I went into this project with wanting the car to still look like a 5speed so i was determined to get the shifter to fit in the stock location. The pro ratchet has the shortest throw i could find so i wouldnt hit the dash when going to park, but it is also one of the overall longest shifters. Im about 80% modifying the opening the get the shifter to sit just right and have all the plastic fit back in normal. I had to cut the shifter up quite a bit in certain areas that didnt really matter. Here are a couple pics. I hope to have the car running by this weekend after it being down since october!!!
-JW Ultra bell
-JW "the wheel"
-RCR flex dipstick
-Ultimate convertor
-other misc. stuff
i was gonna do it the way you did, but it just felt to far for me to reach so i fabbed it up so the shifter moved back more towards me so i dont have to lean forward as much. also the handle in park rubbed the radio delete panel....
im still not fully done i was gonna put a black rubber piece of some sort in the front to cover up all the crap.....
thanks man...yeah 10's are the goal. Im keeping the 100%stock motor in till it blows!
thanks very much!
i don't daily drive the car and i rarely get on the interstate so i didnt need overdrive. also, with the turbo kit i have the stock 3.27 gear and some 28" tires so i can go 70mph and still be under 3000rpm. Another factor was how bullet proof a th400 is compared to a 4r70w. The th400 is WAY CHEAPER as well. I tossed the idea around a whole bunch but i finally decided on the th400 and im glad i didnt do the 4r70w
my clutch went out in october after i went to the track and went 11.4 on 9.5psi. I kept hearing and seeing videos with auto's in turbo cars and i think its the best for my application. Now i have everything built except the motor too
thanks very much!
thats why i chose the b&m pro ratchet, it has the shortest throw i could find. the only downside is the overall length of the shifter. Im actually going to make a different panel to mount the shifter from what i pictured. its still all going to be hidden by the 5speed boot, but im going to go about making a panel out of sheet metal to house the shifter under the boot.
jpplaw
Mar 19, 2025 08:53 AM
Cannibal_carnies
Mar 2, 2023 06:17 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
