01 4.6 Heads and Cams swap
Hello everyone i just recently bought a used 01 4.6 for my 96 stang and im planning on building the motor up to run on the street or strip. I would like to get some advice on which Heads and Cam setup is the best for a bang buck project, also thinking about doing either a turbo or supercharger set up so what would be the best options for a cheap price?? Also thinking about putting a 3500 stall in the tranny.. So if i could get some advice for the pro's on here that would be great! Thanks Guys
I'd call Fox Lake or MMR to do the work on your heads. Both companies do extremely high quality headwork and can set you up with the right cam for your particular application.
My personal preference for headwork would be Fox Lake, they pretty much set the standard for porting modular heads and you will end up spending less than a lot of other shops will charge for "similar" results.
Daddys Girls GTs
09-14-2015 08:46 PM
