Nitrous
Old Apr 14, 2011 | 05:42 PM
  #21
harbre32's Avatar
harbre32
dumb question how does a flip of a switch load a different tune to your ecu? you guys are getting me intrested in this now. is there a "everything you need to know about the juice" thread on here?
Old Apr 14, 2011 | 05:50 PM
  #22
dwtjr3's Avatar
dwtjr3
I am going nitrous! People on here talked me into it (purp did alot of it haha). And what you gotta do is just ask questions even if people think they are dumb do not take offense to em. you gotta learn somehow right? And the tunes are stored on the flip switch its self so when you switch from tune to tune the switch will tell the ecu what tune you want to run
Old Apr 14, 2011 | 06:05 PM
  #23
HamMach1's Avatar
HamMach1
Originally Posted by mrtstang
Yep i run around with the bottle connected, and usually open.
As long as you're not running a big shot, the stock fuel pump should be okay. It's certainly never a bad idea, but probably not necessary.
I hear ya on the cams. $1200 or so just for the cams alone kind of makes it not such a good bang for the buck lol.
Does running a bigger fuel pump have any negative effects while N/A (as in not using nitrous)? I planned on only running 100-125. Seems most guys run a 125 shot.
Originally Posted by dwtjr3
Hammach, listen to these guys. They all really know what they are talking about. I am currently getting my car on the spray and mrt has helped me the whole time. MRT will it hurt the motor if i just run on a nitrous tune all the time? Even when i am not using nitrous?
I am listening trust me. :P
Old Apr 14, 2011 | 06:11 PM
  #24
mrtstang's Avatar
mrtstang
Well i cant speak for all after market fuel pumps, but the SVT pump drops right in, and does not effect n/a performance.
Old Apr 14, 2011 | 06:14 PM
  #25
HamMach1's Avatar
HamMach1
Cool. I'm guessing the SVT pump is the SVT Focus pump?
Old Apr 14, 2011 | 06:15 PM
  #26
mrtstang's Avatar
mrtstang
Correct.
Old Apr 14, 2011 | 06:37 PM
  #27
dwtjr3's Avatar
dwtjr3
I also have a svt focus pump in my room that is getting installed the same time as allllll the other parts i have to install before the ocean city maryland show
Old Apr 14, 2011 | 07:52 PM
  #28
tim2002gt's Avatar
tim2002gt
I am also using the focus pump and it works very well for my power level. Another option for your fuel supply if you don't want to drop the tank is to get a Kenne Bell boost-a-pump to get a little more volume from your stock pump.
As for what mrtstang said about being faster/quicker than blown 2 valves in the same power range, he is very correct. Typically, a nitrous car will make alot more torque and have more power under the curve than a blower car at similar hp levels.
Old Apr 14, 2011 | 08:40 PM
  #29
HamMach1's Avatar
HamMach1
Will I get the same benefit from the boost-a-pump as I would from the svt pump?
Where do you all get most of your nitrous components? Whatever site has the best deals at the time?
Old Apr 14, 2011 | 09:19 PM
  #30
IEGT1015's Avatar
IEGT1015
I would look at ebay, corral or dynotunenitrous.com
