engine assembly lube
Old May 13, 2011 | 12:09 AM
darkstarnes's Avatar
darkstarnes
Default engine assembly lube
I am getting ready to build my DOHC engine and I would like to know from those experienced engine builders which assembly lube have you used and what oil you use for the break in period??
Old May 13, 2011 | 12:43 AM
jvog's Avatar
jvog
By build do you mean you will actually be assembling the shortblock? The reason I ask is because if you aren't actually doing the work, the machine shop or whatever shop is should give it back to you already lubed up.
Old May 13, 2011 | 01:09 AM
darkstarnes
Will be doing it all by my self... no machine shop...
Old May 13, 2011 | 09:34 PM
03SonicBlue_GT's Avatar
03SonicBlue_GT
i use this stuff for assembly lube and usually comp cams break in oil
http://www.lubriplate.com/webstore/detail.aspx?ID=17
Old May 13, 2011 | 09:38 PM
Bman2000's Avatar
Bman2000
i just use standard white lithium grease. its like 8 bucks for a tube big enough for like 3 motors. Ive rebuilt 3 different cars, one being this mustang. thats what i used. And for break in i used regular oil. no addatives no synthetic. Just oil. 5-30. You can spend a lot more money on the break in oils and the special engine assembly lube, but im not sure that it would make a difference.
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
