iac mod
Old 07-06-2011, 02:46 PM
4v_mach1
4v_mach1's Avatar
Default iac mod
Hey guys. Does this look correct? The cars idle dropped to 200 rpm and back up to like 500-600 rpm... shouldn't it be idling around 800 at least? any suggestions? reset battery? drill the other side a bit bigger?
4v_mach1 is offline
Old 07-06-2011, 03:42 PM
4v_mach1
4v_mach1's Avatar
When I'm coming to a stop the car idles at 1200 rpm then it drops down to 200 rpm for a few seconds and goes back up to 600 rpm. Car temp gauge seems a bit higher then usual.
4v_mach1 is offline
Old 07-06-2011, 04:03 PM
4v_mach1
4v_mach1's Avatar
and this is what it looked like what i bought the gasket. I used the metal one and the stock gasket..unless i have to port the other 2 black ones the same size as the metal one and use it on both sides..
4v_mach1 is offline
Old 07-06-2011, 04:32 PM
4v_mach1
4v_mach1's Avatar
I just ported the 2 black gaskets the same size as the metal one and used them on each side of the iac and the car couldn't stop misfiring at idle LOL
4v_mach1 is offline
Old 07-06-2011, 04:34 PM
SVTeeshirt
SVTeeshirt's Avatar
Uhh? Why did you mod your iac?
SVTeeshirt is offline
Old 07-06-2011, 04:39 PM
amoosenamedhank
amoosenamedhank's Avatar
IIRC people where doing this to fix the hanging idle these cars have. There was a sticky rolling around a long time (could still be up there... i'm to lazy to look) about how to do it.
I felt slightly motivated... here you go LINK
amoosenamedhank is offline
Old 07-07-2011, 03:05 AM
4v_mach1
4v_mach1's Avatar
thanks very similar to what i did, but still upset how the car isn't idling correctly.
4v_mach1 is offline
Old 07-07-2011, 05:26 AM
uberstang1
Chupacabra
uberstang1's Avatar
drill the other hole bigger.
uberstang1 is offline
Old 07-07-2011, 06:20 AM
Moonshine
Moonshine's Avatar
Thought about this. It will effect your a/f ratio. Use at your own risk!
You can also put a plug in the tube. Much easier to install/remove.
With both mods, you will hear a loud 'hissing' noise. My cel came on quick like when I did it. Idle still hanging. Annoying. Real annoying.
Moonshine is offline
Old 07-07-2011, 09:08 AM
trailor
trailor's Avatar
did you try cliffyk's method mentioned in that link?? shouldn't affect AFR, seeing as how you're not really restricting airflow into the intake manifold..
trailor is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: iac mod
