question on bullet cam
much appreciated man, surely will swap cams before vortech install. supercharger will arrive tomorrow. v3 self-lubricated system, and custom intercooler.will post pictures and video of dyno when all is done. thanks again for the input.
Actually i'm in the same boat as you. I'm wanting to run a Vortech + meth with my PI MHS stage 2 n/a cams. Long story short...i've talked to both Nick and Mark Chacon (head grinder at Bullet) and while Nick isn't too sure, Mark doesn't recommend it. Granted my specs are a little different than yours, but when the time comes i'm gonna give it a shot anyways. My logic mind tells me that it really shouldn't matter too much with mild boost like 9-12 psi, but who knows lol.
As far as your cams go you have a tighter ICL, but looser ECL, so it might actually work better than mine to be honest. The exhaust lift and duration really shouldn't be too much of an issue IMO. You have more total exhaust emphasis on your specs compared to mine (which is what you want with a blower to avoid heat build up) so if i had to guess i would think they would do fine.
OP, i'd ask Nick just to be sure though.
I'm a huge fan and believer in custom grinds....off the shelfs will work good but to get a cam ground to your exact specs for the same price seems to be a no brainer to me, but off the shelf I would probably just give CMS or MHS a call and see what they recommend. On a stock internal setup with stock pistons/valves they will probably just recommend a stage 1 blower grind
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
