Lowering Advice?
Bilsteins by far. When i installed them, i was amazed at how much more i felt the road. Yet comfort increased drastically as well... Feel the road more AND increase comfort?! You would think it was impossible right? haha
Also my steering felt more "crisp" for lack of a better word.
I am thoroughly pleased with my bilsteins (although i've grown used to them after a while). Nothing like the first few drives with them on though!
Oh yeah and handling improved as well... I just feel more overall grip and have been able to take some turns quite a bit faster...
This doesn't make sense...
First off, the spring is what controls the height of your ride. Shocks and struts may alter ride height SLIGHTLY due to added compression, but you're car doesn't sit on the ground bc of a bad damper....
My tokico HP's were very hard to push in (the shocks were obviously easier to push), but the bilsteins were a little harder to push in than those. I'm a pretty damn strong kid and those things were giving me trouble. All of those dampers took my body weight to compress...
As for ALL of the coils being stacked on each other, that's not right. I know that the H&R SS have a LOT of coils stacked on top of each other, but there are still a few that do not touch. So maybe you didn't quite get a view of all of the spring? I couldn't imagine you getting a bad batch of springs...
This is what your springs shouldn look like...
http://www.google.com/imgres?q=H%26R...w=1024&bih=571
Looking at the picture, the top few coils of each spring will compress and the lower coils will have space between them.
It should look something like this...
http://www.google.com/imgres?q=progr...1&tx=30&ty=212
Where there's space between the coils at the bottom, mine were stacked right on top of each other with no space between any of the coils (from top to bottom). I'm thinking maybe it's because the struts were dead in the front and the weight of the car compressed them? Because I have always heard good things about HR Supersports.
Well I still have the springs and tokico struts sitting here on my bedroom floor. The springs are uncoiled and look new, the struts however feel too weak. I push them in with my arms and it takes about 3 to 4 seconds for it to expand again.
Hmmmm. Well either way the springs are what control the ride height... A shock just controls the bounce of the spring for a smooth ride... If you totally removed your shocks/struts, the car may sag slightly, but overall it's going to stay close to the same ride height. The shocks/struts just stop the osolation of the springs when driving.
As for compressing your struts easily by hand... Some dampers, like the tokicos, should get harder to compress the further you push them down. The bilsteins should be the same difficulty to push down no matter what. Make sense? It's gotta do with the type of dampers... Monotube vs oil dampers or whatever they are
If your springs really are stacking ALL coils on top of each other, I'd give h&r a call...
a lot of people run h$r ss with tokico hp's and have no problem so idk what could be wrong :/ wish I could see the stuff in person and help out
Oh and yes the struts are going to be MUCH harder to compress compared to the shocks. The struts are meant to take much higher spring ratings then the rear so they need the extra dampening.
Ever notice that when you buy springs, the ratings will be like 500+ front and 150-300 rear? Thats why the front struts need to be much stronger then the rear shocks
I have tokico front struts I could sell you. They are used but are still in good shape from when I took em off a few months ago. But make sure it's not a spring problem first...
If your struts are compressing easily, they are shot... Compress them like 10 full times and see if it gets any harder from the first time to the tenth
With the fronts, if the strut is shot, then the full weight of the car could be resting on the spring more than it should. Dampers and springs are not independent of each other in the fact that they manage each other. When not paired right, you get bad ride characteristics as well as poor handling. I do have to warn you that you'll probably have to replace those front springs as they may be worn out completely due to the struts being dead. That may cause an issue here. It might be best to buy new springs.
I really don't fully agree with teej. I just don't see a spring getting worn out, especially if you only had them on for a few thousand miles. The spring is still going to get abused. It's made to "spring" up and down. The dampers control just how much that spring bounces. Is the integrity of the steel in the spring severely compromised when running blown dampers? I personally don't think so, but this is what teej is saying. I've done no research on this. Maybe teej has. So take my opinion as a grain of salt.
I've never had a spring weaken on me, even after i blew my shocks and rode on cut mach 1 springs for X amount of miles. But i didn't run them thousand of miles so i'm just talking out of speculation waiting for teej or someone else with some research to come and prove my argument wrong.
What i can tell you though is that people DO run tokico HP's with H&R SS. Is it the best combo? Absolutely not. Does it get the job done? Most people think their cars ride just fine. My HP's handled my 700+ spring rating up front, but i could tell they were at their limit.
I really don't see your spring being the problem. This would be the first time i've heard of this...
There doesnt seem to be any info out there about this, but it makes sense to me that with poor dampening qualities, that the springs could fatigue and cause them to develop issues. With the springs not having any space between the coils, those springs are not fit to be used on a vehicle. That, and it wont ride for crap. Springs are made from metal, and when fatigued, the metal wont hold its proper shape. Nah mean? Thats why I think that new springs should be ordered.
Thats just me though.
