Input On Next Mods
Old Feb 8, 2012 | 12:32 PM
gameover00's Avatar
gameover00
Thanks alot guys.. I decided to do a little suspension work first. I already have upper and lower control arms. Im adding lakewood shocks and struts, subframe connecters, and new slotted rotors and ceramic brakes. Still confused about which pulley to buy to get me to 10lbs. Would a kenne bell bap be worth buying since im going up in boost? As far as the gears i changed my 4.10 to 3.73. The 4.10 where great but was to much gear for me in a 1/8 of a mile. Was having to shift to 4th gear at the end and was loosing time.
Old Feb 8, 2012 | 09:35 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
I completely agree with JAZZER on the easy upgrade for the brakes.
There is no such thing as brakes that are too good. Fluid, SS lines, and quality pads are practical upgrades. If you go quick, you need to be able to stop quickly.
FLSFC would be my first suggestion for other mods. They will pay off in every performance category.
Sounds like you are mostly interested in how to get to 10# of boost though. Talk to your local tuner for advice on how to get your set-up there.
GOOD LUCK!
Old Feb 8, 2012 | 10:12 PM
gameover00's Avatar
gameover00
im running a intercooler and im getting different answers to what pulley size to go with.. Guess i will ask my tuner.
Old Feb 8, 2012 | 10:39 PM
tdcalhoun89's Avatar
tdcalhoun89
Brakes. Then, suspension.
Listen to Jazzer.
Old Feb 8, 2012 | 10:47 PM
gameover00's Avatar
gameover00
New slotted rotors and pads are ordered. Will change fluid also.. Thanks for the help
Old Feb 9, 2012 | 07:34 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Originally Posted by oxfordgt
The guy isn't into road racing no need to upgrade brakes. I ran 100% stock breaks on my old GT with 700rwhp and never had a single problem stopping in time including when I was doing over 150mph and someone pulled out in front of me.
So you will spend $10K plus on your motor and ZERO on your brakes? You may not have had an issue, but I think to do so is downright foolish! $350 is minimal cost for the vastly superior ability for ones brakes to hold up under intense conditions. Maybe you never experienced such conditions, but if you ever did, that $350 may easily save you an accident or a life. That life.... may be yours!
Jazzer
Old Feb 9, 2012 | 08:36 PM
oxfordgt's Avatar
oxfordgt
I was just saying I don't road race and it doesn't sound like this guy does either. Wether you have 225rwhp or 1000rwhp the car still weighs around 3200lbs and the stock brakes were designed to stop the car at over 100mph. If you're constantly using your brakes like in road racing(using brakes during racing lol that make me laugh) they you you want to upgrade due to the heat created.
Old Feb 9, 2012 | 09:49 PM
school boy's Avatar
school boy
op, listen to jazzer. he's a well respected member and a suspension/brakes/tires guru. upgrade your brakes, its a night and day difference which you will love
Old Feb 10, 2012 | 10:30 AM
gameover00's Avatar
gameover00
Got the subframe connectore welded on yesterday.. I suggest that upgrade to everybody. Made the car alot more stable.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
guitarman376
Sep 30, 2015 05:54 PM
lmurf60
Sep 24, 2015 10:07 PM
