Fuel pump question!!
Old Feb 14, 2012 | 07:50 PM
Lowandslow2v's Avatar
Lowandslow2v
Question Fuel pump question!!
Hello guys hope you are all doing well I have a question I can't find the answer to maybe you guys could help. I have now a walbro 255 but I want to upgrade to the new walbro 400, for more power. Question is with the 400 bolt up?? Is it just a swap of pumps? Or will I have to do some modification? What do you guys think about this pump? Thanks in advance for all the advice
Old Feb 14, 2012 | 11:30 PM
ESABATM's Avatar
ESABATM
Fuel pumps dont add power.
Unless you have the mods needed to support it why change from what to have now? 255 on a stock GT is too much already. All it will do it heat up the fuel.
Old Feb 15, 2012 | 05:12 AM
Lowandslow2v
Car has nothing stock in it I have heads cams built bottem end and pro charger I asked the question for a reason. I know what I'm doing I just need to know this issue
Old Feb 15, 2012 | 09:17 AM
trailor's Avatar
trailor
whats your HP? a BAP may be all you need.
and I doubt a 255 would heat up the fuel on a stocker. its overkill, but it doesn't work more than it has to on returnless style systems (new edges)..
Old Feb 15, 2012 | 11:04 AM
Lowandslow2v
I have 400hp now at 9psi but I'm swapping my intake manifold and upping the boost to about 15psi so I don't want the 255 fuel pump I have now to top out at 500 cause I'm sure the car is going to make more
Old Feb 15, 2012 | 03:47 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
I think a 400lph pump would fry the FPDM as it couldn't keep up with the amps that pump would want.
Old Feb 16, 2012 | 12:46 AM
ESABATM's Avatar
ESABATM
I dont care about your junk dude maybe you should have worded your post different with a little more info.
Whatever.....
Old Feb 16, 2012 | 10:19 AM
Lowandslow2v
Did you get butt hurt? I'm just asking a simple question
Old Feb 16, 2012 | 02:59 PM
ESABATM's Avatar
ESABATM
No this is the interwebz with many db's just like you.
Tivo304
Aug 28, 2023 12:19 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
