2004 gt has a miss
Old 10-04-2014, 11:26 AM
kohrs58
kohrs58's Avatar
Default 2004 gt has a miss
I just bought a 2004 mustang gt with a 4.6 it has 90,000 miles on it. It just started having a miss in it. I replaced the spark plugs and checked all th coli packs with my multi meter, and they all read the same I cleared the codes and went for a ride. it runs better but at high rpms it still misses and the check engine light comes on. I still get the same code p301 any thoughts.
kohrs58 is offline
Old 10-04-2014, 12:57 PM
99GTvert
is my username.
99GTvert's Avatar
You said the multi meter read all the coil packs as the same but were they all in an acceptable rating? Because I was thinking if it wasn't your plugs then it would be your coil packs.
99GTvert is offline
Old 10-04-2014, 01:45 PM
Moderator
JimC's Avatar
Moved from the 2005+ 4.6 for you - watch what sub section you are in when you post. You should find better response here.
JimC is offline
lincolnshibuya
12-08-2015 04:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: 2004 gt has a miss
