Coolant Leak around intake manifold
#21
also, if you plan on using RTV, the correct way would be apply it and then immediately slam it together. Allowing it to dry and fill in the voids with the gaskets torqued and spread. Allowing it to dry first before assembly wouldnt work as well in my opinion
#22
Got it installed! But....
So, I used a high temp permatex, in the pitting, put it all back together, installed a new water pump, new plugs too - Used distilled water, started right up -However, the check engine light is on now and it seems like one of the hoses to the plenum is flattening from a strong vacuum - any thoughts?
#24
Again gotta agree with White Fox.
Take it to the part store and have it scanned, just could be some anti-freeze entered the cylinder during repair.
As far as the hose collapsing, Hmm there is only a couple of hoses that connect to the plenum, IAC hose, EVAP hose, EGR and HVAC. might be forgetting one check to see if they are soft and need to be replaced, post the code if you scan it.
#25
I just have to ask are you confusing the heater hoses with plenum hoses? if the inlet and outlet heater hoses are switched the water pump could collapse the hose.
Just a WAG.
Thermostat in up side down, if that is even possible is an automatic/instant overheat, the point of the thermostat points up, spring goes down.
Good luck
Just a WAG.
Good luck
#26
I’ve got it all back together
Thanks all, luckily I’m not confusing any parts, and they all go in one way lol -
So, check engine light is extinguished- good to go, may have been an anomaly? So, I got everything back in, Used a permatex liquid metal filler, high temp on those pitting sections. Low and behold, two days later, no leaks, except from one side of the fuel injectors which I didn’t have fully tightened- weird! And gas everywhere ( As I drove her yesterday to autozone to return a torque wrench )
Anyways, I still notice one of the vacuum hoses attached to the plenum is pulling a strong vacuum. Any ideas to these types of engines?
Just a WAG.
Good luck
Just a WAG.
Good luck
#27
Vacuum from hose to plenum, and extra parts from intake manifold,
Just posting pics....
Anyways, I still notice one of the vacuum hoses attached to the plenum is pulling a strong vacuum. Any ideas to these types of engines? My step dad was saying it could be an old hose, however, I think it was put there for flexibility? Maybe a braided hose would prevent the collapse?
Plus a couple of extra parts from the intake manifold -
the strong vaccum? Extra pieces from on-line order of intake manifold
Driver side chassis, fuel injector, possible leak without spacers?
Vacuum on plenum hose
#29
PCV Good togo
Well fella's thanks for all the tips and advice. The car ran great for those couple of weeks. I bought a new PCV and hose, and that seemed to work. Now I have a seperate possible clutch issue I will post in a seperate threat, but if you're reading this, he link, I posted it on you tube:
Thanks!
Eric
Thanks!
Eric
MustBeStang
09-23-2013 10:47 AM
MustBeStang
11-06-2012 10:43 PM
texas_stang02
14
10-04-2012 01:35 PM
CyprusMustang
04-05-2009 12:36 PM
