2002 GT Brake issues
Old Dec 27, 2017 | 01:04 PM
rgrimm's Avatar
rgrimm
Default 2002 GT Brake issues
I have a 2002 Mustang GT Convertible I have owned since new. It is a limited use car (24,800 miles) and has always been garage kept. It has only been in the rain twice in it’s lifetime.
My problem is that every 3-4 years the brakes (calipers) start to not release completely, causing the brakes to drag. In 2013 I had all 4 calipers replaced and all the old Fluid removed and replaced with new and the front calipers are starting to not totally release again. I suspect the issue is moisture, since brake fluid (DOT 3) has a tendency to absorb moisture. My research seems to indicate that I can Not change the system over to DOT 5 (silicone – a fluid that doesn’t absorb moisture) brake fluid because the Mustang has ABS brakes.
To clarify ‘limited use’, my GT had 23,400 miles in 2013 when I had all 4 calipers replaced, it now has 24,800 miles on it. So it has only been driven 1400 miles in the past 4 years.
So what do others do who have limited use Mustangs to prevent this brake/caliper problem?
My understanding of the problem with DOT 5 in ABS systems is that the ABS (pulsing) action causes the DOT 5 fluid to foam, thus affecting the brakes (peddle softness). Since my Mustang will never see snow or the types of conditions that would cause the ABS brakes to activate frequently and when the Mustang is driven, it is a Sunday Driver, I’m wondering if I could get away with replacing the DOT 3 with DOT 5 Silicone?
Thank you in advance for any ideas on what I can do beyond rebuilding the brake system every 3-4 years or driving the car ALOT more.
- Russ
Old Dec 27, 2017 | 10:15 PM
proeagles's Avatar
proeagles
What ever you do, don't go DOT 5. How do you know the brakes are dragging? Is it pulling to one side or the other? If the brakes are sticking when you first start the car and pull away, that is simply rust from the pad material sticking to the rotor say from washing the car. Drive the car more to loosen things up. The worst possible thing you can do to a car is not drive it.
Old Dec 28, 2017 | 08:18 AM
rgrimm's Avatar
rgrimm
Originally Posted by proeagles
...... How do you know the brakes are dragging? Is it pulling to one side or the other? .......
After a 5 mile drive I checked the rotary temps, rears were 90 - 95 degrees, left front 105 and right front 170 degrees. I then jacked up each front wheel and while I could spin the wheels, there was a lot of drag (friction), especially on the right front. I performed this same process on my 2013 Edge (primary car) and both front wheels when jacked up, spun with no drag at all, rotary temps were 80 in the rears and 85 in the fronts.
Since I replaced the calipers in 2013, whenever I washed the car (it doesn't get too dirty) I have always taken it for a drive to heat up and dry the calipers, pads and rotors before it goes back in the garage. There is no rust on the rotors' surface, the issue seems to be the caliper piston(s) not releasing and I assume that is from rust caused by moisture in the DOT 3 Fluid.
I guess I am going to have to drive the Mustang more in the future after I replace all the Calipers again. I may start to have the brake fluid purged and replaced each year.
I was just hoping that the automotive fluids industry would have developed a brake fluid that does not absorb moisture and is compatible with vehicles with ABS brakes.
Thanks for your reply.
- Russ
Old Dec 28, 2017 | 01:08 PM
Derf00's Avatar
Derf00
Gentleman's Relish
- Russ
Attachment 76420
Attachment 76421
That is your best option. Or at least every two years. People tend to forget that just because the car isn't driven that often, does not mean that the fluids should not be serviced regularly.
DOT 5 IS compatible with ABS, what is not compatible with DOT 5 is the rubber in the brake hoses, master cylinder, and brake calipers/wheel cylinders (if equipped). Unless you are replacing all of the rubber in your braking system out with Silicon compatible seals, you cannot put DOT 5 into your system.
Old Dec 29, 2017 | 06:46 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
so the right front is dragging correct? crack the bleeder open and attempt to spin the wheel, if it makes it easier then id suspect the hose at being faulty. If cracking the bleeder doesnt alleviate the tension then the caliper would be suspect.
Old Dec 29, 2017 | 06:47 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
just because parts have been replaced in the past doesn't mean they are not susceptible to failure again
Old Dec 29, 2017 | 07:00 AM
rgrimm's Avatar
rgrimm
Actually both fronts are dragging, the RT front just is much worse. I haven't jacked up the rear axle yet to check them.
I'll have to try the bleeder.
All 4 rubber hoses were replaced in 2013 when the calipers and fluid were replaced and from the outside look brand new.
Thanks
Old Dec 29, 2017 | 01:07 PM
Derf00's Avatar
Derf00
Gentleman's Relish
it's not the outside that matters, it's what it looks like inside. Fluid systems rot from the inside out.
Old Jan 4, 2018 | 08:27 AM
rgrimm's Avatar
rgrimm
As you suggested I cracked the bleeder open and it did not release the piston at all. The front calipers are duel piston calipers and in the case of the right front one (worse one) it is only the front piston that is hanging.
So at this point I will have all the fluid drawn out of the system, replace the front Calipers and rubber hoses and fill the system with new DOT 3 Fluid. Then every year or so I will have the brake fluid drawn out and replaced with new ....... AND start to drive the Mustang more.
Thanks everyone for your suggestions and comments.
- Russ
Old Jul 30, 2019 | 08:31 PM
TrevorR00's Avatar
TrevorR00
Is it common for the front calipers to stick? I just did my 1st brake job on my 2000 Mustang GT convertible. I pushed the pistons in 1 by 1 with a proper brake tool (I thought it was odd that when I pushed in the 1 piston in the pair that the other one did not pop out). After the job was done and I pumped the brakes and both front calipers would not fully release. I can't turn the wheels by hand, but I can with a wrench on the lug nut. Since I have replaced my front flex lines and bled the system, but still as soon as I pump the brakes (with the car turned on or off), the front calipers stick. I don't feel any real resistance pushing in the pistons either.
Pjw350
Jun 17, 2009 10:24 AM
01GTDropTop
Apr 1, 2009 03:59 PM
Nick.Simonds
Dec 31, 2008 02:14 PM
massmustang02
Jun 12, 2007 08:00 PM
Guitarhead09
16
Jan 31, 2007 10:19 PM
