Help diagnosing valve tick
Old Feb 11, 2022 | 01:47 PM
Blakekunk's Avatar
Blakekunk
Default Help diagnosing valve tick
Hi this is my first post here but you guys have helped me many times before via google. Any way I did a pull yesterday and then when I left off I heard a ticking it is constant and speeds up with acceleration and down. I know it isn’t a knock because my brothers cobra has rodknock and I heard that pretty recently I just want to know when I take these valve covers off what should be my plan of attack to diagnose the engine I believe it to be a lifter but I’ll leave the Audio clip
File Type: mov
Old Feb 11, 2022 | 01:53 PM
Blakekunk's Avatar
Blakekunk
https://imgur.com/a/SYeyXij
if the video isn’t working for sound
Old Feb 12, 2022 | 10:07 AM
Blakekunk's Avatar
Blakekunk
Anyone
Old Feb 22, 2022 | 08:15 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Most likely timing chain guides worn thru. Youre going to need to at minimum pull the valve covers to inspect the followers and lash adjusters first. Then check slack in the timing chain. My money is a on a chain guide. happy hunting!
Old Feb 22, 2022 | 10:06 AM
Blakekunk's Avatar
Blakekunk
I pulled the passenger one off because it sounded a little more to that side looked at all lifters and lash adjusters and timing chain was nice and tight
Old Feb 22, 2022 | 10:10 AM
Blakekunk's Avatar
Blakekunk
I honestly don’t know what else to look at
Old Feb 23, 2022 | 03:56 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Take both valve covers off and the timing cover. you'll find your issue
Old Feb 23, 2022 | 05:29 PM
Blakekunk's Avatar
Blakekunk
I used a automotive stethoscope and heard it in the passenger valve cover I checked the lifters what else should I check
Old Feb 25, 2022 | 07:12 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
a lash adjuster not pumping up with oil or a rocker arm with a worn roller, if it is indeed in the the head
raftdaddy
Feb 27, 2010 02:29 PM
paddy187
Aug 13, 2008 11:55 AM
cgreen
Oct 5, 2007 02:02 PM
rayj1019
Jun 27, 2006 09:11 PM
badazz68stang
Apr 29, 2006 07:22 PM
