Just ordered the o/r H...
RE: Just ordered the o/r H...
The Mil Eliminators are just to prevent the Check engine light from popping on. The adjustment will need to be tuned, this I'm sure of. Other wise, when Brent "tuned" my car for the O/R Pipe. What exactly did he tune? It's not like he stopped them CEL from popping up, because I had to use the tuner to search the code, then delete it. I'm still 100% positive that the ECU has to be adjusted due to the lack of the Cats.
Go to his website and see for yourself ...clickey on h pipe ...it says no tune required . This was going to be my first mod , when I talked to Brent he said no tune is needed but would throw a code without the mil . I went ahead and picked up the sct with his tune which turns off rear o2s . I figured if I was going to buy mil eliminators that I would just buy a tuner since I was going to need one anyway .
wellllll...this is what brent told me..
Hi Joe we do use a new tune for the off road H pipe if you are running our custom tune. If you are running the stock Ford tune you are fine but you will need MIL’s to turn off the check engine light. If you are running our tune there is not charge for the re-tune as long as you bought the H here.
THANKS
THANKS
bradleyb
11-27-2015 07:50 PM
