Issues after Hurst install
Old Jul 18, 2007 | 06:43 AM
Rudiepoo1's Avatar
Rudiepoo1
Default Issues after Hurst install
Ok....recently a buddy of mine installed the Hurst competition plust shifter. The first two days were fine then on the 3rd while getting on the highway I noticed that the shifter was making a small rattleing noise coming from where the handle mounts to the shifter. If I hold that area the noise would go away. That night I check the allen bolts and their tight as hell. The next day was fine but then later on it started happening again. Any suggestions on what else to check? He's planning on going through everything this weekend. I also noticed that when the shifter is in the neutral position that I can lift up on it, like there's a little play there. It can lift up slightly then goes back to stock resting position. I checked out a Shelby GT at a local dealer and the Hurst that was installed was not able to do anything like this so I know there's an issue, we just have to figure it out.
Old Jul 18, 2007 | 01:15 PM
acascianelli's Avatar
acascianelli
Default RE: Issues after Hurst install
Put some loctite or some other threadlocker on the bolts.
Old Jul 18, 2007 | 02:10 PM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
I have the Hurst short throw and there is no play at all, especially vertically.
Old Jul 18, 2007 | 02:12 PM
Rudiepoo1's Avatar
Rudiepoo1
Yeah.....we did put loctite on the allen bolts at least - the ones that attach the handle to the shifter. That part is not loose. We'll have to check everything else.
Old Jul 18, 2007 | 02:17 PM
Margarita Girl
Wish I could help you out, but I had mine installed by the local shop. He did transfer a part from the old shifter to the new one. I also had him install the gasket from cobrabob to keep out any road noise.
www.stangshiftergaskets.com
acascianelli
I have a little horizontal play, but thats because I had to reuse the bushings from the factory shifter. I need to order some Steeda poly bushings and swap the crap rubber ones out.
Old Jul 18, 2007 | 04:40 PM
Rudiepoo1's Avatar
Rudiepoo1
ORIGINAL: Margarita Girl
We did transfer everything we were supposed to via the instructions as well I also installed one of the gaskets from cobrabob as well. I'm thinking about exchanging it for another. When it was working fine I loved it!
Granatelli Sales
Jan 20, 2020 12:34 AM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
