4.10 gears
#31
RE: 4.10 gears
I have heard you get a lot of gear whine with the 4.10s? Plus your mileage goes into the toilet? Sadly I have to do a lot of freeway driving and don't want to be driven crazy by the gear noise...Help?[sm=helpout.gif]
#32
RE: 4.10 gears
ORIGINAL: AguynamedJay
I hope to max out these gears in the 1/4 mile very soon by trapping 121 at 6krpms in 4th! That's with a 27.8 inch tall tire by the way.
Here's a niffty little calculator that will show you the mph for any rpms in any gear with any ring and pinion using the tire diameter of your choice.
http://www.angelfire.com/fl/procrastination/rear.html
#33
RE: 4.10 gears
ORIGINAL: moosestang
That maybe true with some gears, but not the FRPP 4.10's I had installed. My install said if i went with 4.30's I may get some whine, but there shouldn't be any going from 3.55's to 4.10's.
after a week or so you will abs hate 4.10s, you will kick yourself for not going 4.30 in a 5 speed
#37
RE: 4.10 gears
What is the difference between the 4.10 and the 4.30 in regards to the 5 speed automatics? Also I see that alot of people went with 3.73 on the automatics. I am just trying to find out what everyones experience is before I spend the money to get this done.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
