Old Nov 4, 2015, 12:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
how do we remove a fuel pump?
Old Oct 2, 2007 | 03:49 PM
fayazmustang's Avatar
fayazmustang
Default how do we remove a fuel pump?
ok people i have a 2005 mustang gt with procharger, we strongly believe the fuel pump is done. car doesnt start. gets spark . fuel doesnt arrive to the injectors. we want to know how to remove the fuel pump? anyone have any idea?
Old Oct 2, 2007 | 04:17 PM
hammeron's Avatar
hammeron
Default RE: how do we remove a fuel pump?
sure...the fuel pump removal procedure,
is part of the whipple install....get it here
http://www.users.qwest.net/~cookpaging/whipple.pdf
* also, make sure fuel is getting past the fuel filter,
before going through all the trouble
Old Oct 2, 2007 | 04:24 PM
howarmat's Avatar
howarmat
s197 Junkie
Here are some gt500 fuel pump install instructions....that should help you out enough
http://www.modular fords.com/forums/attachments/f79/41005d1184095082-gt500-fuel-pump-installation-frpp_gt500_fuel_kit.pdf
Old Oct 2, 2007 | 05:54 PM
moosestang's Avatar
moosestang
You should be able to hear the fuel pump run for a few seconds when you turn the key on. If not then check the relay first, then check the fuel safety cutoff switch in the drivers side footwell.
Old Oct 3, 2007 | 04:21 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
good one moose....you beat me to it!
Old Oct 3, 2007 | 01:15 PM
D_Gusler's Avatar
D_Gusler
Just a word of advise: its real easy to change the pumps on these cars--just remove the back seat & two covers over the pumps.
Old Oct 4, 2007 | 01:26 AM
fayazmustang
ok i replaced the fuel filter, i turn the key on ignition and i do not hear the fuel pump. but i checked the fuel pump relay fuse. i switched it out with a spare. works now. but blows the fuse again after awhile during drive, then car acts retarded. any clues?
Old Oct 5, 2007 | 02:46 AM
alloutt's Avatar
alloutt
Make sure you disconnect the battery or it could just keep happening...
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
uberstang1
Sep 20, 2015 06:42 PM
wawagner82
Sep 13, 2015 09:02 AM
5.0 kevo
Sep 3, 2015 06:24 PM
