GEARS
Old Dec 12, 2007 | 11:51 PM
danGT06's Avatar
danGT06
Default RE: GEARS
No if you plan on having anything over 400rwhp then 4.10's are going to be a waste. If you are planning to SC I would just stick with the stock gears.
ORIGINAL: EXile88GT
would it be a good idea to put 4.10s in the car if i plan on boosting it?
Old Dec 13, 2007 | 09:55 AM
EXile88GT's Avatar
EXile88GT
Default RE: GEARS
what about 3.90's. i hear some people say its the best of both worlds. only problem is i dont know anyone whos had 3.90's
Old Dec 13, 2007 | 10:03 AM
danGT06's Avatar
danGT06
Default RE: GEARS
Well the most popular gears are the FRPP ones and they don't make 3.90's. You can get Motive 3.90's but I have read that they tend to whine. Its not an easy decision. I chose just to save some money and stick withthe stock gears because I plan on getting a SC very soon.
Old Dec 13, 2007 | 06:42 PM
SpeedRacer9220's Avatar
SpeedRacer9220
Default RE: GEARS
I have 4.10 in my auto and I love them. I do 98% of all my driving in the city. To avoid the lugging feeling around town I drive with the OD turned off. I am also running 20" wheels which effectively lowered my ratio to about 3.90 due to the tire diameter. i dont know about having to reprogram the shift points though, mine seems to run strong and not shift any later than before. When I contacted Doug at B A M A Chips about needing a new tune with the addition of the 4.10's he said it was not necessary. Just make sure that I changed the ratio to correct the speedo.
Old Dec 16, 2007 | 08:52 PM
2007GT/CS's Avatar
2007GT/CS
Default RE: GEARS
ORIGINAL: danGT06
ORIGINAL: EXile88GT
I respecfully disagree.
Old Dec 16, 2007 | 11:27 PM
danGT06's Avatar
danGT06
Default RE: GEARS
Well if you have stock tires with 4.10's and over 400rwhp and rwtq I have no idea how you ever plan to use first gear again. Unless you plan on running DR on a daily driver. I've seen guys at the track on street tires with 4.10's and no SC that can't get traction. I'm sure its lightning quick though out of second and third.
ORIGINAL: 2007GT/CS
ORIGINAL: danGT06
ORIGINAL: EXile88GT
Old Dec 18, 2007 | 06:22 PM
EXile88GT's Avatar
EXile88GT
Default RE: GEARS
what if the rear suspension was built up pretty good? would it help the traction issues?
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
