reprogramming speedo after gear change
just had 4.30 gears put in my stang. the last gear change i did was on a 95. just replacing plastic gear in tranny fix speedo. what about my 06. what is the process. thanks
RE: NEED INFO ON SPEEDOMETER RECAL AFTER GEAR CHANGE
Yeah a programmer, The sct diablo and others have different parameters you can change when you plug them into your car. Read up on them (search) and learn about Getting the car "tuned" I am not sure how much you know of these devicesbut basiclly it changes some of the information your computer uses to send/recieve info from your cars engine/transmission and gauges. They are usually simple plug in and follow directions......
OH! it does make a heck of a difference
hope this helps you. A lot of people on here use tunes written by companys that will sell you a tune and handheld (a little genericbut works great). A good alternative is going to a dyno and having your car tuned to your Mods and gas you are running.
Good luck with yor car and let the MODS begin.
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
