the adaptive learning
Old May 18, 2009 | 09:53 AM
  #21
ski's Avatar
ski
Originally Posted by ShadyNinja
weather wind sun all wee the same it was a calm sunny day
not a lot going on
car is a auto with stock 3.31 gears so not a lot of wheel spinning going on
the trans shifted about the same all day
I ran sum 13.3-13.4's before the disconnect
after a bunch of 13.6 and one 13.5
FWIW, don't do a disconnect if it's running good.
Old May 18, 2009 | 09:48 PM
  #22
ShadyNinja's Avatar
ShadyNinja
I know but there was only 1 wat to find out that.
if its not broke.....
don't break it!!~~
Old May 18, 2009 | 10:34 PM
  #23
slowstang06's Avatar
slowstang06
so i have a lot of mods that are dependent on the tune... (lol TB and CMDPs!) and while before my tuner uploaded my dyno parameters to my handheld (id recommend having them do this for you guys, so if it gets sluggish, just retune yourself!) but this last time they didnt (since i got the TB and CMDPs =[) recently i've driven really conservativly (shifting before 2000 etc) so would disconnecting the battery for like 30 mins be ok, or would that risk putting me in safe mode?
Old May 19, 2009 | 10:38 AM
  #24
ski's Avatar
ski
Disconnecting the battery only removes the adaptive learning data(incl. max speed, max rpm, and # of times the rev limiter was hit) that's been stored in the ECU's KAM(keep alive memory). It should not alter or lose your car's tune.
Old May 19, 2009 | 11:57 AM
  #25
157dB's Avatar
157dB
Cut & Paste Expert
well here is some info.
I was at the drag strip
I made 3-4 passes, and decided to pull the cable to see if resetting the ecu would help out, I left it unplugged while we ate lunch (over 1 hour)
hooked it back up,
made about 5 more passes( temp ,wind etc were all about the same)
the last 5 passes were 1-2 tenths slower
Resetting the ecu FTL!
You basically just reset the adaptive learning back to the
factory defaults (bad).
You really should have followed the adaptive learning relearling procedure
before making those last 5 passes.
The engine was basically limping on the factory defaults.
No wonder the times were slower.
Were you expecting them to be faster why?
Old May 19, 2009 | 12:43 PM
  #26
ski's Avatar
ski
don't break it!!~~
You misunderstood my meaning => If the car is running similar to how it ran under the same conditions previously, then don't mess with anything.
Yantorno
Sep 30, 2015 10:29 AM
dudeguy421
Sep 24, 2015 11:16 AM
Sminemann
Sep 17, 2015 09:24 AM
Ford_Dude
Sep 15, 2015 03:25 PM
Doogie65
Sep 6, 2015 02:55 PM
