Driveline Vibes
#21
If METCO says that their instant center brackets aren't for a street car shouldn't you suspect that the same thing goes for their control arms with the delrin bushings? We didn't suspect a pinion angle issue being your problem since you told us that the LCA's were non adjustable. This is the first mention of these instant center brackets. I would suggest going back to the OEM LCA's or at the very least LCA's with poly bushings. We're sorry that you are having problems. Your dilemna is a good example as to why you shouldn't do too many mods at the same time. It makes pinpointing the cause of a problem much harder.
#23
Somewhere in this you said it was good and then got worse. I think it was after the gears were set up for the second time. To me this would signal something changing like bolts loosening up.
So here's one more idea: Have you checked the adapter plate bolts? I have a different brand of aluminum ds but it also uses an adapter plate. The instructions for torquing the adapter to the pinion flange and ds bolts to adapter were incorrect. They stated "about 25 ft. lbs" for the flange to plate torque and "about 30 ft. lbs." for the ds to plate torque. If I would of followed these torque values my plate would of loosened. The bolts were just snug at those values.
Just something else to check.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
