Supershaker Install Questions
Looking to do an install on my dad's (toy4bob) car this weekend. I have a few questions first. I was looking at the required tools for install and saw Coolant system pressure tool. Went down to the local Auto Zone to see if I could rent one and the only thing they had was a coolant system pressure tester. I assume this will work but wanted to make sure? Also I installed steeda UDP's last year and now they have to come off. Which type of gear puller do I need to get the crank pulley off?
Thanks
Thanks
I can't help you on the coolant part but for the crankshaft pulley you want to use the puller with the three jaws that grip the pulley. I believe it is called the Chrysler puller or something of those sorts. If you are renting it an auto parts store should be able to help you out.
http://www.fordspecialtools.com/detail.aspx?id=1236
Thats the exact tool for pulling the pullies if you want to buy it.
i thought i had seen these at harbor freight
tools, so i checked just to be sure....it sure
looks close...and much cheaper if purchasing..
http://www.harborfreight.com/cpi/cta...emnumber=32184
Funny story on returning the harmonic balancer after installing the Steeda. He forgot to put some of the parts back in the case and returned it, getting back the $50 or 75 deposit. Got home and noticed the parts, and of course took back. I am guessing someone woulda got a major reaming had someone noticed the missing parts before we got em back. Guessing that guy opens all other cases before returning deposits in the future though.
Shifty Magoo
08-25-2015 03:08 PM
