Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: Why is My Electric Power Seat Not Working?
Step by step instructions for do-it-yourself repairs.
AC/Heater fan not working...
Good to hear you got it working. I know my wipers work so it's not a fuse for me. The fact that I can jiggle the fuse box for my issues seems to indicate it's just a loose connection. Just yesterday I turned it on and it worked for 5 seconds and then probably from the bumps in the road, it turned off again. I'll be sure to update here once I check the fuse box connections.
It did get stuck on high (4) recently and that was due to the resistor module that goes bad and doesn't provide any resistance so all fan positions are stuck on high (no resistance). The funny thing was that I replaced that module with a replacement a while back trying to troubleshoot the blower issue and it turned out not to be the issue, but I left the replacement in since it was in and done. So when the fan got stuck on high recently, I knew what it was and I put in the original module that came with the car and that worked. Nice to have spare parts laying around and ones that are original and older than the replacement parts.
i’m having the same issue, ive replaced the blower motor, blower motor resistor, ac clutch relay, blower motor fuse, im getting power to all the connection, sometimes it blows and works fine sometimes nothing blows at all im lost i dont know what else it could be other than ground or pcm issues
Sorry to hear you're having so many problems after replacing just about everything. Someone above mentioned the actual fan switch (in the dash I assume) might be the problem. Have you tried replacing/checking that? Maybe you can bypass it to see if it stays on when not using the actual switch.
When it blows does it blow at the correct speed or only high speed? Since you've replaced the resistor it's probably not that since even if it went bad again, it would blow at full speed.
It sounds like it might be the switch. Someone mentioned above "I have helped with many blower problems and it tends to be the connector on the fan switch itself that cannot handle the fan/resistor currents without overheating and loosing all connections." if you haven't seen that. There is also a schematic: https://iihs.net/fsm/?d=40&f=Manual%...l%20System.pdf
I'm not a mechanic, but I've fixed a lot of things. I would try messing with the switch and continually switch it to see if it's reliable. From the info above, if the switch can't handle the fan currents without overheating, I assume that when the fan is on the highest speed, the most power is running through the switch.
And not knowing what the switch is like, maybe you can get it out and set something up to set it on speed 2 or 3 by bypassing the switch to see if it runs longer without the switch in the mix.
I just had this problem on 2007 gt replaced blower resister under dash didn’t work then I had to take passenger side floor panel off and bumped the wiring harness connector and the ac blower came on there is a big white connector that had a burnt pin connected and it melted that part of the connector went to the salvage and found a good connector bought a pin remover on Amazon $15 and marked and labeled wires and replaced the bad connector repaired wire worked great a word of advice to disconnect the connector it has a lever you have to pull on one side of the connector so pay attention
gentlejax2
Sep 2, 2006 11:21 AM
2003 GT Mustang
Apr 9, 2006 05:17 AM
