Engine mods for more boost?
If you were to do the labor yourself and it's going to be torn apart, iwould do the following:
send the heads out for porting
get a cam based on whatever power adder you choose.
stroke the motor to 298 ci.
use ARP fasteners and head studs.
research the proper type of rings and gaskets for FI
after you figure that out then you think about your fuel system.
I contacted the instructor and he said that we can work something out. If something needs to be sent off and worked on, it might be an issue because of timing and schedules of the project.
I might just get an E-Force kit and make that my project instead. I can have 430whp now and then do the internals later, rather then the opposite ( engine now, SC later)
Either way, I don't mind!~
Calizic
Aug 28, 2015 01:46 PM
inyadreems
Aug 21, 2015 09:10 AM
