Oil in intake
Old Sep 16, 2009 | 09:00 PM
Mustangyoe's Avatar
Mustangyoe
Default Oil in intake
I took of my throttle body today and I found that there was a a coating of oil in the intake. Is this a common thing or do you think that the crankcase vent is bad? My car is a 2010 GT with a little over 1000 miles.
Old Sep 16, 2009 | 10:57 PM
DRock's Avatar
DRock
our cars have a blow by design witch shoots unused oil back into the intake( could definately be wrong) but a lil is ok but on a car with 1000 miles that seems a little odd
Old Sep 16, 2009 | 11:01 PM
onederful100's Avatar
onederful100
i got 2 words for ya, oil separator.
but just how much oil is in there? got pics?
mine had a little in there when i had 5k miles.
you could do oil separator, catch can, or crank case breathers. those will solve your problem, if its just regular blowby.
Old Sep 17, 2009 | 09:21 AM
Mustangyoe's Avatar
Mustangyoe
There isnt much oil in there just enough to see a film of it inside the intake. I think I am going to put in a oil seperater to see how much I pull out.
Old Sep 17, 2009 | 12:48 PM
shanec's Avatar
shanec
The car is designed for this to happen.
When I removed my intake to install my supercharger, I was surprised at how much oil was in there. I mentioned catch cans and oil separators to Edelbrock and they said not to bother and that the car was designed to work this way. There's nothing wrong with it.
Old Sep 17, 2009 | 05:38 PM
mxg30's Avatar
mxg30
^^^ What he said^^^ This is common and NOT a problem. Please do not waist your money on an oil seperator unless you just like the look and to say that you have one . You know everytime you use your trans as a break to slow the car down is when you allow most of the oil to form around the intake. No harm, but why would you remove your intake with so little miles?
Old Sep 17, 2009 | 07:10 PM
tx_zstang's Avatar
tx_zstang
I would think most of the oil comes from the pcv valve; it gets into the intake by design.
A filter between the pcv and intake will stop that.
Old Sep 17, 2009 | 08:43 PM
Mustangyoe's Avatar
Mustangyoe
I was looking to see how hard the Steeda delete plugs would be to install
Vrooom
Feb 21, 2016 05:25 PM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
kevsgt
Sep 9, 2015 06:20 AM
