I have no (functioning) scanner to post the dyno results. My first pull was 283.51 RWHP and the second pull was 299.26 RWHP which is a difference of 15.75 HP, but I know that a part of that is because the air was cooler outside. The only modification between the two Dyno pulls was the UDPs.
Thats pretty solid, how about the butt dyno? Did you notice any difference in it? If so at what range did you notice it most? Low or High? Also any problems or anything caused from the UDPs so far?
