3rd gear going out?
Not that I could tell. Everything just felt stiffer and shifting was much more solid.
Right here: http://www.brenspeed.com/che7la.html
hummm (adds that to his list of things to get) might have to pick one up later I missed 3rd once or twice out of the 5 or 6 runs, not a good ratio.
You can achieve the same desired result with a new set of motor mounts instead of the k-member brace and limiters...but i thought the brace would be easier to put in, so that's what i bought.
I think your right, adding a brace underneath has to be easier than messing with the motor mounts. plus if it's anything like my older cars once you put in stiffer motor mounts you gain a lot of vibration and noise.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
