DIY 8 Rib Conversion
Old Oct 5, 2010 | 10:39 PM
  #21
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Great write up Bruce!...I think this will make its way to be a sticky...
Old Oct 9, 2010 | 03:54 PM
  #22
hammeron's Avatar
hammeron
good call mygt500!
congrats bruceh, you are now a sticky crew member :-)
Old Oct 22, 2010 | 10:40 PM
  #23
DiMora's Avatar
DiMora
Originally Posted by BruceH
I just pieced together an 8 rib pulley set up for my motor.
Parts list:
YB542 A/C compressor clutch pulley
GP720 Alternator pulley
38052 8 Rib idler pulley
300-006 Power steering pulley
38028 76mm idler pulley X2
38022 90mm idler pulley
4081252 Goodyear gatorback belt
3.500" Whipple Cobra pulley
10% overdrive Innovators West balancer
All parts except for the supercharger pulley and balancer were purchased for under $200. The Whipple pulley was $55 used. Balancer was $425 shipped. A Navigator balancer could be substituted for under $100.
Did you use the same water pump pulley from the 6 rib setup?
Old Dec 31, 2011 | 10:53 AM
  #24
tomkay's Avatar
tomkay
Default alternator pulley doesn't fit
I just ordered the pulleys for my 2008 and everything was going ok until I got to the alternator. My car has the new clutch pulley on it and the GP720 does not. Is there an alternate 8 rib clutch pulley? Thanks for any help and for the great write up on 8 rib conversion.
Old Apr 2, 2012 | 04:35 PM
  #25
Whippled06's Avatar
Whippled06
I saw all the part numbers you listed but where did you order all of these?
Old Apr 3, 2012 | 08:10 AM
  #26
flounderlipps's Avatar
flounderlipps
Rock Auto
Do a part number search
Parts list:
YB542
GP720
38052
300-006
38028
38022
4081252
http://www.rockauto.com/catalog/raframecatalog.php
Old Apr 4, 2012 | 07:35 AM
  #27
Whippled06's Avatar
Whippled06
I went with a 3.5 because I also used a 10% overdrive balancer. I'm making more boost with that combination than I was with a 3.250 pulley and stock balancer.
All I can say is shop around. They turn up from time to time. Check ebay and the classifieds of all the forums you belong to.
How much before and after boost did you make? Is there any specific reason you went with the 3.5 instead of something even smaller?
Old Dec 26, 2012 | 05:18 AM
  #28
crownaviation's Avatar
crownaviation
Some of those pullies (most) are from a 03-05 f250 6.0L turbodeisel econoline van IIRC. I found all but the AC compressor pulley at the local parts store. Paid more tho.. I just use my stock water pump pulley and no problems. Thump sells some real nice billet smooth idlers in an 8 rib also. They were worth it to me, and just upgraded to their 76mm dual bearing idlers.
Old Oct 14, 2014 | 06:34 PM
  #29
2nd2nunn's Avatar
2nd2nunn
Does anyone have the alternate routing for the e force with the in 18%od
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
spdeplayer2
Oct 24, 2015 09:45 AM
