O2 Sensor Problem
Old Aug 7, 2010 | 06:38 PM
Swervin309's Avatar
Swervin309
Default O2 Sensor Problem
I recently installed a pair of no-name shorties that i bought from Ebay. After working out the kinks i started getting a P2197 (Left-side stuck lean) code. Is changing the tune needed on shorties or do i have a problem with the sensor? I've checked everything from wiring to possible leaks. Everything is normal.
Old Aug 10, 2010 | 01:00 PM
jerjan's Avatar
jerjan
I had this problem after I installed an off road X-pipe. It turned out that I had an exhaust leak at the flange. It was sucking in oxygen under accelleration. Basically it ruined the 02 sensor. So check for a leak, fix it, clear the error code see if the code comes back. If it does you will need to replace the sensor. The underlying problem is usually an exhaust leak before the sensor. Even a very small leak can be a problem. Good luck!
jma2
Jul 10, 2023 01:00 AM
Jb145700
Aug 21, 2022 06:37 AM
articman
Jun 21, 2018 11:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
