Oil leak from Driver side Cam sensor.
Old Nov 2, 2010 | 05:03 PM
TekMan05's Avatar
TekMan05
Exclamation Oil leak from Driver side Cam sensor.
Recently discovered I got a leak coming from that seal on the Driv'ers side Cam sensor on the Cam cover. I did recently install an Oil separator and did notice that one side was crimped down too tight therefore was pinching on one side. Could that pressure build up cause that? Big thing being, How do you go about replacing this? Am I gonna have to pull the cover off?
Old Nov 2, 2010 | 05:39 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
How did you discover the leak?
Did it run all the way down to the ground or did you just happen upon it
while opening the hood?
I believe you are going to have to take the cover off but I am NOT certain.
We need a better voice in here to help you.
Old Nov 2, 2010 | 05:51 PM
TekMan05's Avatar
TekMan05
It pooled a little bit around the cam sensor and dribbled down on the inner side of the cam cover by the coil pack . I did kinda have this weird hunch because I was starting to get a faint oily smell in the air when driving on the Highway.
Old Nov 3, 2010 | 07:52 AM
top00cat's Avatar
top00cat
I would pull the valve covers and check the gasket. If the seal is broken it is going to continue to leak
Old Nov 3, 2010 | 09:25 AM
jwog666's Avatar
jwog666
are you talking about the cam seanor on the front cover, or the vct solenoid that protrudes from the valve cover?
Old Nov 3, 2010 | 10:03 AM
Doogie65's Avatar
Doogie65
If you are referring to the VCT sensor pictured below, the cam cover will require removal which is outlined on this handy TacoBill "How-to".
Old Nov 3, 2010 | 12:13 PM
TekMan05's Avatar
TekMan05
Yup that is it. It's gonna be a pain in the *** to replace but should be done. I wonder if Brenspeed sent me a defective cam cover. When I installed my Detroit Rockers I orders the powdercoated Covers to go with it. So when going to the dealer to order the part? WHat should I be looking for , and how do I remove the old one?
Old Nov 3, 2010 | 01:55 PM
Doogie65's Avatar
Doogie65
Check the link in my last thread as that How to covers the cam cover removal along with that seal.
Old Nov 3, 2010 | 05:10 PM
TekMan05's Avatar
TekMan05
Okay , cool cool I see it now. Thanks that helped alot. I'll go to the Stealership tomorrow and try to see if they can give me the right part.
soulcaliber39
Dec 28, 2016 04:57 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
kirk35
Aug 17, 2015 08:42 PM
