car revs on its own, and stalls
Old 01-23-2011, 11:18 AM
mb2
mb2's Avatar
Had the same problem with my gt had to change the battery and the TPS went bad its common when doing any kind of battery or alternater work the TPS goes bad replaced it and shes fine now
mb2 is offline
Old 01-23-2011, 12:51 PM
JAMAMAN
JAMAMAN's Avatar
This is a long stretch, but maybe the spark plug wires are wired wrong. Some D--k head at the dealership did that once to my car by accident.
JAMAMAN is offline
Old 01-25-2011, 09:16 PM
Never2mucHP
Never2mucHP's Avatar
OP: What you describe sounds very much like a vacuum leak. The car should be throwing a CEL; if you can download that it would go a long way to letting you know whats going on.
A good indication is if it's throwing the code for "O2 sensor stuck lean" or something similar it is almost certainly a vacuum problem.
The guy above that stated TPS problem may also be on to something as this would also cause a similar situation.
Never2mucHP is offline
djbigskrilla
09-20-2022 01:04 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
stanngg
08-12-2015 03:43 PM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: car revs on its own, and stalls
