PCV issues
Old Feb 28, 2011 | 02:08 PM
Throck!'s Avatar
Throck!
The E-Force doesn't have that many vacuum/EGR/PCV/any other air tubing. I double checked with the instruction manual, looks like everything is where it's supposed to be. (It's been on for about 4 months and only blows the dipstick out under peak boost)
Where do you get an oil tube filler breather?
I looked again with the borescope, there was a proper drip under the pulley. I'll take the pulley off after work today to see what I can see, maybe take pictures.
But like Justice, Dysan, and Simon1 say, it doesn't explain why the coolant colored substance is being aerated and dropped on the floor occasionally. (maybe it'll show up again soon so i can take pictures)
I'll have somebody check the oil and water soon.
So no clue on if the dipstick is supposed to have an o ring? It pulls out pretty easily, may just be easier to push that out than going through the passages and baffling to the PCV valve.
I've tried the PCV suck test I read about somewhere, seems to have very little resistance, the tubing/oil separator seems to have very little resistance also.
Also, there's no pressure when I open the oil fill cap after running it 'hard' or revving it a few times.
Anyway, if the worst happens, I'll probably just get a B302 short block. I kinda figured I'd need one in the next few years anyway.
Also, thanks for the help everyone.
Old Feb 28, 2011 | 09:36 PM
black2010's Avatar
black2010
Originally Posted by Throck!
Th
Just went out and checked my 2010 for you. Mine has an o-ring on the dipstick tupe. It also took a good yank on it to get out. That may be part of your problem as it should have the o-ring and be snug in the fitting.
Sounds like you have some other issues to check out to though.
Old Feb 28, 2011 | 11:29 PM
Simon1's Avatar
Simon1
YOu can look in the anti freeze tank and see oil if it's there. Same thing with oil. Drain and see.
Is your bypass valve working correctly?
Old Mar 1, 2011 | 09:52 AM
Throck!'s Avatar
Throck!
Thanks for checking on the o-ring. Someone must have removed it at some time.
The tank will be easy enough to look at. I need to get the oil changed anyway, I'll do it when things stop coming up.
Didn't get to pull the water pump pulley off last night. Had to go eat steak last minute.
Bypass valve....are you talking about the boost bypass valve? I think it's working right. Has vacuum until I get into the gas, then goes up to ~5 psi.
Old Mar 1, 2011 | 07:30 PM
Throck!'s Avatar
Throck!
Ok, moved the water pump pulley aside to get a better view of it...do our water pumps have freeze plugs? The fluid appears to be leaking from a freeze plug. It did get to -20* a few weeks ago.
I have pictures, but I'm not sure how to insert them.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
lmurf60
Sep 24, 2015 10:07 PM
