Surging issue
Old Aug 10, 2011 | 10:07 AM
Southern Stang 722's Avatar
Southern Stang 722
Default Surging issue
Hey mf'ers, I did some searching and couldn't find what I was looking for so I'll ask and see what you guys think. The car has surging issues when driving with the a/c on. When it is off it runs smooth as can be. At first I thought it was because of my delete plates but after it ran smooth with the a/c off that ruled that out. Sometimes if I run the car without a/c for a little while then turn the a/c on it goes away but not always.
The throttle body is clean
I do know it's about time for plugs
All mods are listed in my sig....This surge is just really starting to get annoying and would like some insight on this problem. Thanks for your help folks.
Old Aug 10, 2011 | 06:53 PM
Southern Stang 722
It now does it while the ac is off also. It had the p0340 which the alternator did have a bad diode. Had the guy replace the rectifier bridge, and a few other things that needed to be replaced while he was in there. So any ideas?
Old Aug 10, 2011 | 10:13 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Check for an vacuum (air) leak from the air intake up to the throttle body.
Feel ALL around the area and make sure to check ALL around the area, meaning the back parts that face the ground.
If you have had a new tune installed lately it could be the tune as well.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
MacSerio
Sep 27, 2015 01:05 PM
lmurf60
Sep 24, 2015 10:07 PM
