Going for a custom turbo build.
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
I would like to use this thread as a stockpile for all info needed to custom turbo a 2008.5-2010 3v. At this point in time, I don't really know all the facts, but I do know the basics. I already have a cxracing 4" air-to-air from when I had my v6 procharged.
I will be basing the system from a single turbo, and I will tune the car to about 400-425hp, depending on what you guys think I should safely operate at. I drive the car hard almost daily.
Turbo is an ebay gt45: Should be reliable? If the turbo turns out to be crappy, I'll just replace it again, it's cheap.
I will be spending a good amount of money on an external wastegate since it is the most important piece.
What should I do to my fuel pump? I figured I could do the fpdm wiring mod. Boost-a-pump and that's it?
Smallest injectors I can use?
What can I use for the header? Should I just reverse it and point it forward? Or bring a pipe forward from under the engine?
How do I find out the oil orifice for the gt45?
What's the best way to construct the hot a cold piping without breaking the bank?
More questions later, thanks in advance guys.
