cam question
Old Feb 8, 2012 | 06:21 PM
DTMR's Avatar
DTMR
Default cam question
Im ordering my ford racing cams and ford racing valve covers soon,also the stupid wedge tool and the bolts and I'm doing the job with the engine in the car, but I was wondering because i have enough for the cams right now and i do plan on upgrading the fuel system with bigger injectors and rails later will adding cams with the stock fuel delivery system cause too much lean? I know I can tune it out but I just wanted to make sure
Old Feb 8, 2012 | 06:56 PM
Fuel's Avatar
Fuel
Will you be upgrading the fuel system for FI? There really isn't any reason a stock motor with boltons can't run just fine on the stock fuel system.
Old Feb 8, 2012 | 09:25 PM
DTMR's Avatar
DTMR
no I'm not running boost as of right now but i was wondering if it would be a problem with the upgraded cams cu more air in the engine
Old Feb 8, 2012 | 10:09 PM
HxCGuitars's Avatar
HxCGuitars
Many, many people run cams with a completely stock fuel system. You've got nothing to worry about.
Old Feb 8, 2012 | 11:34 PM
JCON's Avatar
JCON
The FRPP Hotrod cams with muffler deletes (and nothing else) give you a great and noticeably better power band. I didn't run A/F ratios but when I drove one that had that set up, it felt great! You do get some good peak gains but the most important thing I noticed was the non-peak gains and smoothness of the delivery. I almost feel sometimes like a stock GT has a dead mid-range but cams really woke it up. I plan to get the FRPP cams in mine. Your stock fuel system will be fine.
Old Feb 9, 2012 | 07:26 PM
DTMR's Avatar
DTMR
okay great thanks guys
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
