3650 tranny fluid change?
I know this topic has been beaten to death but after reading all the posts I could find, I'm still confused. I want to change my fluid and I have 5 qts of Dexron III in my shop. I have seen guys says to use Moble 1, RP Amzoil and Dexron III.
Seeing I have 5 qts of Pennzoil Dexron III, should I just go and use that? I do have some grinding issues from 1st to 2nd gear at RPM's over 4,000 - 5,000 at times.
Your thoughts?
Your thoughts?
Ford recommends Mercon V as you probably know, although I understand that Tremec recommends Mobil 1 ATF or Dexron III (don't quote me on that). I'd say if you use the Dexron III also add Lubegard to make the Dexron III act more like Mercon V just to be safe.
The tremec web site states dexron III for the 3650. I know ford says dexron V but i understand thats wrong.
I'm leaning towards RP, I'm going to call Tremec tomorrow just to see what they say.
LivingInThePast
09-16-2015 12:20 PM
jaiidutch
09-14-2015 10:29 AM
