header and x pipe installed
Old 04-03-2013, 07:42 AM
S197GT07
S197GT07's Avatar
What part of mass are you from? I may have some tuning suggestions based on your location.
S197GT07 is offline
Old 04-03-2013, 07:57 AM
mgil
mgil's Avatar
cape cod
mgil is offline
Old 04-03-2013, 10:06 AM
S197GT07
S197GT07's Avatar
Well rats.
The truth is, you should get a tuner. Its the single most important thing you'll ever do for the car, and for $300 you cant go wrong. You could also pick one up used for a bit cheaper.
Order one up from AM, specify your longtubes, and the car will not only run better but your CEL will disappear.
You'll fail emissions, but we can cross that bridge when the time comes.
S197GT07 is offline
Old 04-03-2013, 03:21 PM
mgil
mgil's Avatar
just had the car scanned throwin codes po133 and po153 , both front sensors , even with the high flow cats i'll fail emmissions ? what can be done about failed emmissions
mgil is offline
Old 04-03-2013, 08:24 PM
drewsky
drewsky's Avatar
A tune and CAI is the best bang for the buck on these mustangs. Cheaper than the exhaust system you had installed and wakes the car up by a long shot! It will most likely fix the codes you are throwing as well.
drewsky is offline
Old 04-04-2013, 05:45 AM
mgil
mgil's Avatar
Originally Posted by S197GT07
Well rats.
even with the high flow cats ill fail emmissions? how does that get fixed?
mgil is offline
Old 04-04-2013, 09:09 AM
20binafd
20binafd's Avatar
you don't need to worry about emissions until you sell, don't you? Also I think you should disregard what I said last time about not needing a tuner, it appears with LTs your car needs to be adjusted for the change in the O2 sensor location; found this in another post
"the theory is that moving the front O2's from their OEM location to about 1.5 feet farther downstream causes the O2 to heat up later...but the PCM is still looking for the self-test at the same time. So the O2 "fails" and the PCM never goes closed loop. Makes the car A/F go pig rich and then CEL's and poor driveability."
source thread: https://mustangforums.com/forum/4-6l...t-headers.html
So maybe invest the $380 getting this
http://www.americanmuscle.com/x3-cus...er-0510gt.html
and that will fix your code problem, make sure you aren't running rich, make more power, let your run higher octanes (making more power), let you install a cold air intake (and make even more power).
Good luck
20binafd is offline
Old 04-04-2013, 10:57 AM
S197GT07
S197GT07's Avatar
There is a chance. Usualy the tune will turn the rear O2's off, which will fail you.
If you turn them on, you may get codes for cat low efficency, which will fail you.
Lol. Here in Taxachusetts we have to pass the OBDII inspection every year.
S197GT07 is offline
Old 04-04-2013, 04:18 PM
mgil
mgil's Avatar
So i may have to re install the stock tune before i get a sticker? would that solve the issue? I didnt have a problem with the cel until one time i started the car and didnt let it warm up enough, prior to that i had been letting the car warm until the idle settled and it wasnt throwing codes .
looks like in canada they arent required to get yearly inspections, which aint a bad thing for sure .
mgil is offline
Old 04-08-2013, 08:15 AM
S197GT07
S197GT07's Avatar
Not really. You have 2 options when you go with headers & midpipe. High flow or catless midpipe doesn't matter.
1) Use spark plug non foulers. These essentially pull the rear O2's out of the exhaust stream a bit, thus they see less flow, and think the cats are working great.
2) Get a tune that will get you to pass. Unless they've changed, I don't think any of the online tuners will do this for you.
S197GT07 is offline
Quick Reply: header and x pipe installed
