Voltage regulator
Old Jan 27, 2014 | 08:42 PM
priestly86's Avatar
priestly86
Default Voltage regulator
My mustang suddenly started pushing way too much voltage to my battery today after I gave it a good 6000 rpm burn out. as soon as i did this my lights went out, abs and tcs went out too. now it wont regulate properly. Autozone told me its not my regulator. so now im lost as to what to do. can anyone help me out?
Old Jan 27, 2014 | 11:55 PM
tx_zstang's Avatar
tx_zstang
Yeah, forget autozone for testing the alternator; they can't properly test the one from these cars.
How do you know you pushed too much voltage and not enough? Sounds like a typical alternator failure. Dont get a replacement from autozone; you'll be replacing it soon.
A place that rebuilds alternators can properly test it for you, but it sounds like yours is on its way out.
The regulator is build into the alternator and it is actually what gives the biggest problem.
Old Jan 28, 2014 | 03:18 AM
akdoggie's Avatar
akdoggie
The brush pkg is bolted to the regulator and the brushes grind into the armature really deep, and when the rpm's get high, the rotating speed causes the brushes to lose contact, and wear extremely quickly. You mostlikely will need a new alternator. GL.
Old Oct 19, 2015 | 08:13 PM
barta5088's Avatar
barta5088
can you buy rebuild kits? i have a 200amp paperformance alternator. The tester at the garage said 10.6 volts. Looking to rebuild if possible. any place to get a rebuild kit, is it some what easy?
Old Oct 20, 2015 | 07:04 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Here ya go:
http://www.americanmuscle.com/paperf...epair-kit.html
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
