Old 10-23-2015, 06:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang V6 Tire Repair and Maintenance
Print Wikipost
Brake Help
Old 07-27-2015, 09:42 AM
DTMR
DTMR's Avatar
Default Brake Help
Hey guys,
I need a pad that can handle autocross/track but is still okay on the street. Ive been leaning towards the EBC but I would like to hear from anyone who have used them before. Any experiences? Thanks!
DTMR is offline
Old 07-31-2015, 03:22 PM
Eric62
Eric62's Avatar
I used EBC yellows on stock solid rotors. I did not like them at all as a track pad. OK on the street. Really poor initial bite. Did NOT give me confidence when hitting the brakes at the end of a fast straight. I prefer Hawk products. HP-S pads for street, auto-cross and mild track days. They are metallic so they will dirty up the wheels pretty quickly but they will stop the car with authority stop after stop.
If you are an experienced track driver and heavy on the brakes, the HP-S will tend to overheat/fade and wear out pretty quickly. Hawk R compound should be a good compromise street/track pad. Any more aggressive and you are into full race pads like Hawk Blues or DTC-70's. BTW, stay away from drilled rotors for hard track day stuff with race pads, they will crack thru the holes. Stick to slotted, not drilled.
Eric62 is offline
Old 08-05-2015, 10:36 AM
Norm Peterson
Norm Peterson's Avatar
HPS will get you through a careful, cautiously driven introductory track day, but don't ask them to do any more than that. They are decidedly NOT track pads . . .
If you want good bite, very good fade resistance, and minimal rotor wear for track use . . . in a word - Carbotechs.
DTMR - If you're at all familiar with NJMP, XP10's are enough pad to support running 20+ minute sessions of consecutive 1:21-ish laps on Lightning and upper 1:30's on Thunderbolt. Think intermediate and advanced run groups respectively. And they're certainly streetable enough to drive to and from the track on (or even daily as long as you can cope with some dust and a little noise from time to time and remain consciously aware that their cold bite won't be as strong as when they've got a little heat in them).
Norm
Norm Peterson is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake Help
