Surging
Old Sep 4, 2016 | 10:58 PM
Jbg42's Avatar
Jbg42
Default Surging
I have a 2006 mustang GT, 4.6 ltr. The only mod I have is Roush cold air intake. At low RMP, around 1500, it has a tendency to surge or buck. I can get the rpm's up and have no issues. The engine light is on so I got it scanned and its throwing cam sensor on the number 1 bank. I read into it and I've been told that a voltage issue caused by the alternator can do the same thing and throw the same code. Any thoughts??
Old Sep 5, 2016 | 08:35 AM
bl817's Avatar
bl817
yep. replace the alt sooner rather than later, before it leaves you stranded. I would replace it with a 2010 alt. I think there is a minor pinout change in the plug but not 100% sure. you can search about that. do you have a tune for your CAI or is it a "no tune required" CAI? good luck and welcome to the forum!
Old Sep 5, 2016 | 09:29 AM
Jbg42's Avatar
Jbg42
The CIA doesn't require a tune unless I take the baffle out. I do think it's getting too much air so I am going to get a timer and take the baffle out. Will the low voltage cause the surging?
Old Sep 5, 2016 | 01:30 PM
bl817's Avatar
bl817
low voltage can cause all kinds of problems. you can have it (alt and battery) checked. I think its more involved to test the actual diodes in the alt. clean the TB and the MAF sensor as well. good luck
Old Sep 5, 2016 | 01:51 PM
Jbg42's Avatar
Jbg42
Thank you for your time. I will check these issues and let you know what I find.
trackers
Feb 18, 2017 11:45 AM
lukemcnally
Feb 26, 2016 07:16 AM
staish
Jul 7, 2007 01:30 PM
The_Game
Nov 18, 2003 11:31 PM
baileed
26
May 2, 2003 01:44 AM
