Tranny Swap
Tranny Swap
hey guys i own 2005 v6 but i found someone that has a 2007 v8 he says the tranny is slipping im thinking aout trading my perfectly running v6 for his non running v8 i have like 80 percent chance of him saying yes so here is the question sice i dont want the automatic i can just buy a manual 5 speed “i got the money saved up” ik i will need the clutch pedal i can get that from a crashed v8 in a junk yard or order it from a ebay but will i need anything else is the driveshaft the same length for Automatic and Manual and is there anyway to bypass the clutch on the computer or will i need a computer from a manual transmission also if i was to need the computer am i gonna need to program it or can i just swap them and good to go thanks in advance
For what you're going to pay in parts and labor, you could sell your V6, add your swap
money, and buy an 05-07, GT 5-speed.
Example:
https://www.facebook.com/marketplace...18107895029018
The 5W55S can be had for as low as $575.
However, the manual swap has been done, you need the ECU from a manual as well.
Example:
About the ecu
Example:
Example:
You also need a brake masker from a standard for the slave cylinder in the
trans. If you look at the auto, there is a tube that comes off the master
but it's heat pinch welded shut. There is no barb on it to connect the
hydraulic line for the manual.
http://www.mustangandfords.com/how-t...smission-swap/
The brake and clutch are on one assembly.
XxphantomsnypzxX
03-14-2006 10:39 AM
