05-09 4.6l engine compatibility
Old Apr 12, 2020 | 11:12 PM
Aidin Freeland's Avatar
Aidin Freeland
Default 05-09 4.6l engine compatibility
Stupid question but are all the 4.6 engines compatible with each other? Like would a engine from a 07 fit a 05?
Old Apr 13, 2020 | 02:22 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
All the 05-10 short blocks are the same. The only differences are:
1. 08-10 engines have updated spark plugs and different coils.
2. 09-10 engines have intake manifold with integrated charge motion control valves. Earlier ones had a separate CMCV assembly.
3. 09-10 engines have updated and more reliable Denso alternator.
4. 07-10 engines have different water crossover at front of intake manifold with integrated thermostat housing, and less radiator hoses.
Old Apr 13, 2020 | 03:22 AM
Aidin Freeland
Would I be able to put a 07 engine into a 05 mustang without having to modify anything?
Old Apr 13, 2020 | 09:53 AM
Aidin Freeland
so would I be able to swap a 07 v8 into a 05. There's a one out a 2007 near me with 50k miles and comes with tranny and everything on the engine. Would I need to modify anything to put in in?
Old Apr 14, 2020 | 04:42 AM
Dino Dino Bambino
It'll drop straight in. If the engine's fully dressed, just remove the water crossover from the 07 and swap the one from your 05.
It's a good opportunity to upgrade the stock exhaust manifolds to headers if you can fit them into your budget. They're easy to do while the engine's out. You might also want to replace the engine mounts with new OEM units if yours are 15 years old. Again, it's easy to do while the engine's out, and you can clean the engine bay to have it looking smart for the replacement engine (which you can also clean before it goes in).
I'd advise you to replace all coolant/heater hoses and the drivebelt as preventive maintenance (especially the heater hose assembly under the intake manifold) as these would be a PITA to do later on.
SVTERMINAT0R
Feb 20, 2010 12:03 AM
TylerLe22
Apr 11, 2008 01:46 PM
jmis
May 20, 2007 12:47 AM
Apoptosis
Aug 28, 2006 02:08 PM
jonny
Jul 25, 2004 04:10 PM
