4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Motor problems HELP
Old Dec 28, 2006 | 10:39 AM
bcozzi71's Avatar
bcozzi71
Default Motor problems HELP
ok i need your help, my 4 banger is missing alot, i though i fixed it but now when i first start the car its fine but once it warms up it starts missing. im thinking i need to replace the plugs which r in sad shape and the sparkplug wires.....but do u think the timing is off aswelll????
Old Dec 28, 2006 | 02:26 PM
nismotunedgtr's Avatar
nismotunedgtr
Default RE: Motor problems HELP
Might as well put a set of Autolites in her. They are cheap.
What year is it? It would help alot if we knew if it was Mass Air or not.
Old Dec 29, 2006 | 12:06 AM
bcozzi71's Avatar
bcozzi71
yea its a 1992
Old Dec 29, 2006 | 03:05 AM
nismotunedgtr
Try cleaning the MAF (Mass Air Flow Sensor).Remember to disconnect the battery too.
Could possibly be a O2 sensor, if you say it runs like poo once it's heated up.
Old Dec 29, 2006 | 10:56 AM
bcozzi71's Avatar
bcozzi71
the only problem with that is a replacement mass air sensor is couple hundred $$$$
Old Dec 29, 2006 | 12:13 PM
disturbed471985's Avatar
disturbed471985
You shouldnt have to buy a new one just clean it.
Old Dec 29, 2006 | 01:34 PM
nismotunedgtr
Yup, just take it out and spray the little sensors with some MAF cleaner from Napa.
Should cost $5 or less.
Look on google for instructions on cleaning it. Very simple
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
