Leaking gas!!!!
Leaking gas!!!!
Just found out my gas tank is leaking fuel from the grommet. Herei thought i was running rich because of the smell of fuel... anyhow, any of you guys know how difficult it would be to fix this problem?
RE: Leaking gas!!!!
take the three bolts inside the fuel door out, on bolt on the filler neck under the car and the neck pulls out. pull out the grommet, push the new one in and reconnect the neck, takes about 10 minutes very simple. i will do mine too eventually but i need a new sending unit also, so i will do it all at the same time.
RE: Leaking gas!!!!
So thats it huh... looked harder than that... Thanks man, you look into www.50resto.com, they have some of the best prices i've seen so far.
