4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Key Problems
Old 05-19-2008, 02:33 PM
macinnisjesse
macinnisjesse's Avatar
Default Key Problems
Hi i have a 1992 Mustang LX 5 speed
my key isent going in the ingnition i bought the car 2 days ago and it was working fine until one time i tryed to put the key in and it just wouldent go in the problem isent the steering lock.
anyone have any idea what this might be when i try to put the key in it just dosent go in like it dosent fit but it should its the same key as i have been using since i got the car.
macinnisjesse is offline
Old 05-19-2008, 02:54 PM
sleeper_inc
sleeper_inc's Avatar
Default RE: Key Problems
make sure nothing is in there.
make sure your also using the ignition key and nt the door one.
sleeper_inc is offline
Old 05-19-2008, 02:58 PM
macinnisjesse
ok ill try that
Old 05-19-2008, 09:56 PM
al_ngl
al_ngl's Avatar
I bet your "dinger button" got stuck down. Does your dinger go off even if your key isn't in the ignition? If so, you need a new ignition switch. I had to have mine drilled out, and I was stranded at wal-mart for 4 hours[&:]
al_ngl is offline
Old 05-20-2008, 12:02 AM
7_Zero
7_Zero's Avatar
I would say that al_ngl hit it right on the head.
LOL, this very thing happened to me as well. I had to abandon my car over the weekend until the locksmith could come and swap it out. When they put the new one in, they just pulled off the trigger so it would not happen again.
7_Zero is offline
Old 05-20-2008, 03:09 PM
al_ngl
al_ngl's Avatar
Yeah the locksmith told me that the dinger button is the Achille's heel of fords.
al_ngl is offline
Old 05-20-2008, 09:51 PM
pfs4life
pfs4life's Avatar
i kno exactly wat it is
the same ****in thing happened to me in the school parking lot
you need a pick
an angled or straight doesnt matter
look down in there and ur gonna see a piece of wat looks to be brass
dig the pick down in there and get that **** outta the way and it will be fine
but dont force the key and bend it
thats not good
pfs4life is offline
Meystang
09-25-2015 04:05 PM
SteelerNation82
09-16-2015 07:11 AM
09-10-2015 08:39 PM
09-08-2015 11:50 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Key Problems
